Since Avery is no longer in business I need to locate a hidden hinge for RV7
R RVTOY Well Known Member Jun 2, 2016 #1 Since Avery is no longer in business I need to locate a hidden hinge for RV7
BillL Well Known Member Jun 2, 2016 #3 Google is your friend. http://www.cleavelandtool.com/Oil-Door-Hidden-Hinge/productinfo/RVHH1/#.V1DFwVdcLZY http://www.airpartsinc.com/HIDDEN_OIL_DOOR_HINGE.htm
R rv7charlie Well Known Member Jun 2, 2016 #4 or... Stare at one for about 2 minutes & then grab your seaming pliers & some scrap aluminum.
ChiefPilot Well Known Member Jun 2, 2016 #5 RVTOY said: Since Avery is no longer in business I need to locate a hidden hinge for RV7 Click to expand... Just make one. Easy peasy. http://www.vansairforce.com/community/showthread.php?t=108270
L lr172 Well Known Member Jun 2, 2016 #7 I got mine at McMaster Carr. They don't have the long ones like Cleveland makes. Mine were about an inch wide and I used two of them. Larry
T Tomcat RV4 Well Known Member Jun 3, 2016 #8 I used spring loaded gas cap door from Dodge pickup, other sizes on other pic!ups, as most don't use cable release like cars.Tom
