Where do I find this fuel fitting?
Theflightrisk
I'm New Here
Removed cleaned the fuel servo strainer and went to reinstall. Leaks at the flare. Where can I find a new one of these fittings?
Yes flex fire sleeved fuel line from mechanical pump to the fuel servo inlet. Not sure what I did wrong for it to leak after cleaning the strainer. It seemed weird using the crows foot in there for final torque.
The typical standard practice is that a fitting installation to a piece of flex hose is a one time thing.
Many of the fittings are reusable if installing them on a new piece of hose, but installing a new fitting on a previously used piece of hose is generally considered a bad idea.
At this point, the best plan would be to get a new hose made.
A fairly reliable fix if you hadn’t taken the fitting end off of the hose, would have been to use a Dell seal between the flared fitting and the hose end.
It is a thin, soft aluminum form fitted seal that gets compressed when the nut on the hose end is fully torqued, and is a pretty reliable solution for fittings that are being problematic.
If you removed the hose end because the leak was located between the hose fitting and the hose, then I think having this problem was a good thing. Because a properly made hose should never leak at that point and probably needed to be changed.
Thank you so much. Those dell fittings are cool.
If I buy a new fuel hose do you have recommendations? Figured if I replace the hose also get new an fitting. Would you recommend steel or aluminum? Thanks.
