I had a very tiny oil leak for a while.. never enough to make a drip on the ground, but the engine was always wet. One day after a flight, I noticed a small spot.. “That’s new” so I decided to decowl it and look around..
Good luck with it. I would send a pic to divco and see if that is repairable. Kind of thinking no, but often surprised what they can weld up and place back in service.I’m not sure what caused it yet.. the original builder seemed to do a great job with it.. the bracket wasn’t loaded against the boss.. the bolt does look a little long but I can thread it in all the way without the bracket, and it doesn’t bottom out or “pull” the boss away from the engine.. so I’m not sure the reason yet. The fixed pitch Sensenich was properly balanced..
As for the pain of discovery, it’s ok.. thankfully finances are good, and I’m glad I caught it in my hangar, at home, instead of having the oil blow out, leading to a seizure and having to dead stick it into a dry lakebed, hours from civilization, and then needing to figure a transportation plan back to home base!! (Or worse, crashing/wrecking the plane)
With gas prices at a record high ($7.30 and climbing) now isn’t the worst time to take a flying break!
I’m torn between having a local shop do the overhaul, having Aerosport Power do it, or taking on the experience myself, either way, I’ll take the opportunity to do some desired upgrades sooner than later!
Thanks for the kind responses and well wishes.. I’ll keep y’all updated!
I’m taking the opportunity to upgrade to the B&C externally regulated setup anyway, but I’ll look closer at the old alternator.I would have the alternator checked for an imbalance or whether the case attachment point was stressed by misalignment.
I appreciate your perspective, not everyone would handle this setback gracefully.I’m not sure what caused it yet.. the original builder seemed to do a great job with it.. the bracket wasn’t loaded against the boss.. the bolt does look a little long but I can thread it in all the way without the bracket, and it doesn’t bottom out or “pull” the boss away from the engine.. so I’m not sure the reason yet. The fixed pitch Sensenich was properly balanced..
OH MY that does seem to need a bit of attention. Never in a million years would I expect something like that to happen.I appreciate your perspective, not everyone would handle this setback gracefully.
Best wishes for a smooth rebuild and getting your (new) ride back in the air soon.
^^^^It’s also a reminder that being a capable aircraft builder and being a trained mechanic are not quite the same thing. There’s overlap, but they are different skill sets.
Make sure that little bracket is installed between the alternator and starter.That’s a pretty remarkable failure. The boss was designed to carry that bracket load, and if this were a common weak point I’d expect we’d hear about it more often.
Without knowing the installation history, I wouldn’t want to assign cause. But I would be looking closely at over-torque, bracket misalignment, incorrect spacers, side-loading, or some other installation-induced stress.
Not required with B&C.Make sure that little bracket is installed between the alternator and starter.
I sure wouldn't run without it...no matter the alternator type. It keeps the twisting moment down to a minimum, regardless of the alternator "style"Not required with B&C.
Would there be a downside?Not required with B&C.
+1That’s a pretty remarkable failure. The boss was designed to carry that bracket load, and if this were a common weak point I’d expect we’d hear about it more often.
Mine was a nippon denso style, and it didn’t have that little bracket, but I do think it’s a good idea to have one in there..Make sure that little bracket is installed between the alternator and starter.
