Wheel Pants Flat Head Screws
Does anyone know the size/nomenclature for the flat head screws on the wheel pants?
Thanks!
Jeff
8-32 by 1/2 on the brackets, typically 6-32 100 deg on the shell half's but that depends on nutplates used. Torx, hex or No 2 Phillips. Is that what your question is? Also, your plans from Vans Aircraft should specify.
The wheel pants were an add on by the original builder and I have no plans. These are the flat head screws that hold the shells together, not the bracket screws.
