JwWright57
Man these wheels are really a PIA lol
First i had them assembled incorrectly, valve was pointed towards the inside of the rim.
Changed it around and all was good.
Checked the toe/in out with the string and blocks the alignment was perfect, wont need any shims.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Went to put the wheels on and the bolts holding the axles to the gear leg rub against the inside bearing. See picture. I added a third washer on the backside and that pulled the bolt out enough so its not rubbing. Anyone else have this problem?
https://photos.app.goo.gl/tA5uHgqUk1mZpYQd6
Also just noticed the washers under the axel nut are missing. The were supposed to come with the break/tire kit according to the plans. Just one more fing thing to resolve. I'm guessing I'll have to contact Matco for those
