Yeah-- what a "grab bag" of directives! (I sense lawyers in the background). Each part of Section 3 (the heart of the document), parts 3.2 through 3.18, has tasks for Operators and for Maintenance people. Some of the directions are very general, others very specific. Some are old news ("increase rpm before mp"), others won't apply to you (e.g. since you have a -iS engine, every part about carbueretors, which I still can't spell even though I've overhauled them for 50 years). I plan to go through with a highlighter to mark the portions that apply to me.SB-912-079 is 35 pages of mandatory what, exactly? I'm not "getting it."
Looks like an attempt by ROTAX to cya for non-standard installations and reminder to OEMs and owners to operate the engine correctly. Yes I agree not much new for an RV-12 owner in this but I imagine there are many engines being misused in everything from aircraft to airboats. Basically illustrated by the stated requirement and reminder to OEM's from ROTAX that a MAP gauge be installed and operate the engine per the graph on pg 12.SB-912-079 is 35 pages of mandatory what, exactly? I'm not "getting it."
My interpretation is this SB is only applicable for "912 S/ULS (Series)", and none of this would apply to a 912iS. But I'm fairly new to SBs and could be mistaken......others won't apply to you (e.g. since you have a -iS engine, every part about carbueretors, which I still can't spell even though I've overhauled them for 50 years). I plan to go through with a highlighter to mark the portions that apply to me.
As others have implied, I believe this only applies to the 912 S and ULS engines with carburetors. I suspect there will be a similar SB on the way for the 912iS.SB-912-079 is 35 pages of mandatory what, exactly? I'm not "getting it."
I can confirm the knock sensor, if installed, is not enabled, on the 912iS. I do not know the reason why this is the case, only that it is the case.I may need to go to one of the Rotax classes. It would be nice to know more about the 912iS before I start flying behind it.
Reading through the SB, there appears to be several items that are intended to help prevent detonation. My initial assumption was computer controlled timing on the 912iS would have a knock sensor and adjust the timing as needed to prevent detonation. But after a quick Google search it appears that may not be the case. According to forum posts... earlier 912iS came with a knock sensor that was never enabled for ignition timing, and later models don't even have a knock sensor. It would be interesting to talk with an official Rotax source and see if this is true, and what made them decide not to go ahead and enable the sensor.
I think you're right, that this applies to the ULS and not the iS engines -- which would explain why there is no content specific to the injected engines, while much of the info refers to operating the engines with carbs.My interpretation is this SB is only applicable for "912 S/ULS (Series)", and none of this would apply to a 912iS. But I'm fairly new to SBs and could be mistaken...
