The issue is that "if you go with EAB (experimental amature built) and a simpler panel", you may find you can't get it registered because the RV-12 hasn't been approved under the 51% rule. At that point, it would be pretty expensive yard art until the builder converted it back to the stock configuration for the RV-12 ELSA...
