After I am done riveting two parts using the pneumatic squeezer I noticed that some of the rivets manufacture heads are a little bit bent and their bottoms are not flush with parts. I found out that was because the work was not clamped tightly and the squeezer flex moved the two parts so I fixed for the remaining rivers.
Do you think I should drill out those rivets although the shop heads look good?
