claycookiemonster
These things are beautiful, but they are not cheap. So, I measured the set up compulsively and carefully several times. I mocked up the cable runs with 3/8" hose. I measured the throw required at Prop Governor and Throttle and Mixture arms many times. I transferred this distance to the Throttle Quadrant (Acft Spruce SMCT3L) and redrilled several holes to get the needed throw. It was going to be PERFECT.
And then it wasn't. Despite all of the above, all three levers at the quadrant are restricted from going full aft by something we cannot see. We are finding ourselves considering drilling new holes in the quadrant levers to change the throw again. While there are some curves required in the cables, for example to route the prop cable to the rear mounted governor or to the throttle arm on the right side of the engine, none of the curves are very sharp. I'd expect everyone to have to do similar curves to get the job done.
We discovered this yesterday, Friday, and McFarlane was closed before I could call for help. So, I'm calling here. HELP!
