txnbuilder
Active Member
Since this appears to be one of the most challenging parts of the build, I figured I'd better get this cleared up before touching anything ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The manual says something like "When the forward ribs of the WD-716 canopy frame assembly are manufactured, the flanges are not 90 degrees. Use a file to remove some material from the aft edge of the upper flange so it is 90 degrees when checked with a square..."
Is this what they are referring to?
Thanks!
Thanks!
