VP200 new CU
Smitdog43
Member
Replacing CU on VP200. Manual states that when doing so you must update application software and then import settings for settings file.
Application software filename looks like : 2007_06_11VP.tgz
I have no application software files (not the builder) and see no help on Vertcal power website.
My DU currently shows I’m running application software version 21.1-r and am really hoping someone can forward a copy of this file.
FYI I was able to export the settings file…… just need the application file.
Thanks much,
Steve
713-502-9081 cell
already contacted steve,
but in case someone else needs this:
latest release was:
https://www.flyvans.com/vp200/2011_12_22r2301f_200VP.vpd
release notes:
https://www.flyvans.com/vp200/release_200_2012.pdf
and if you had a system on an older software, you needed to install first this release, before being able to go to the latest:
https://www.flyvans.com/vp200/2009_10_19r2006i_200VP.vpd
would be very interested knowing who else still operates their VP200 and is interested in keeping them running?
