Does anyone know the size and a source for Viton o-rings for the brake calipers on a RV10?
K kenmorris Active Member Jan 28, 2011 #1 Does anyone know the size and a source for Viton o-rings for the brake calipers on a RV10?
RVRC Well Known Member Jan 28, 2011 #2 Ken, I don't know the size, but a local rubber and gasket store should have most sizes of viton o-rings in stock. I am pretty sure there is one in Garland. Not sure where you live.
K kenmorris Active Member Jan 28, 2011 #4 here is the size: MS28775-326 or AN6227-29 these are not viton ID = 1 5/8" OD = 2" width = 3/16"
A apirkle Member Jan 28, 2011 #5 Ken - if you're in McKinney, try Seals & Packings in Richardson. http://www.sealsandpackings.com/
S Strasnuts Well Known Member Jan 28, 2011 #6 Here is the easy way to get them Viton O-rings part number M83248/I-224 V-75 at McMaster Carr under part number 1201T856. It looks to me like everything matches up and it is mil spec.
