Vertical Stabilizer Wiring Conduit
burrm
Member
Hello all,
This is my first post here, although I have been lurking for some time. I have been a pilot for many years but I am a complete "NOOB" when it comes to home building. Nonetheless, I am embarking on an RV-10 build, the first step of which I am sure you all know is the vertical stabilizer.
Looking around the web, I have seen a few folks who have modified their vertical stabilizer to include one or more wiring conduits by drilling one or more 3/4? holes into the web of the VS-1006 top rib and adding a doubler in order to facilitate the penetration of the wiring conduit(s).
I like the idea of having the flexibility for wiring extra lights, cameras, antennae or whatever in the future, and especially like the flexibility that homebuilding affords us to make such modifications as desired.
That all being said, and given my total lack of experience with such matters, I have not been able to find any engineering references regarding the implications of a modification such as this. For example, how is the appropriate size and thickness of the doubler determined, what are the risks or implications of going too small/big or too thick/thin? Are there implications (other than aesthetics) of placing the doubler either on top or on the bottom side of the rib? How many rivets should be used to attach the doubler? How is this determined?
I?ve consulted AC 43.13, as well as FAA-H-8003-31A but didn?t find any specific reference that was relevant, although admittedly given my lack of experience I might not recognize it even if it is there. The closest I could find was toward the end of chapter 4 in the latter book starting on page 4-105 ?Rib and Web Repair?, where it talks about patches being the same gauge as the original material or one gauge higher, two rows of rivets properly spaced, etc.. However, this is talking about repairs to damaged ribs as opposed to intentional modifications with doublers.
Perhaps I?ve watched too many episodes of ?Air Disasters? on TV, but before making a seemingly significant modification like this, I would like to make sure that I have fully done my due diligence and fully understand all of the implications, have convinced myself that I will be doing it ?properly? and with proper references noted in the builder?s log etc.. I guess given my lack of experience I'm not comfortable jumping into it merely based on reading a few internet posts, any more that I would start sawing holes through load-bearing walls of my house without understanding the implications and/or consulting with a professional.
I know the obvious answer is "if you're not comfortable and don't know what you're doing, don't do it and just stick to the plans". I get that, but in addition to making decisions regarding this one specific potential modification, part of my larger goal here is also to educate myself. I feel like if I am going to be a successful homebuilder, I should know how to research such items, what data to consider in order to make informed decisions and choices, etc.
Thanks in advance for any wisdom and/or opinions anyone cares to offer.
-Mike
Hi Mike. Good question, that I don't necessarily have the answers for, but can talk about the approach I used.
I'm not sure of documentation for the proper size, thickness, and rivet spacing of doublers. In the past, when I added doublers not according to plans, I just followed the rough dimensions and spacings of other doublers that were in the plans. But a person does have to be careful to not overdo it either - a doubler will naturally increase the stiffness and strength of a part. Increasing the strength should have no ill effects, but if the increased stiffness is too abrupt of a transition from the part on its own and the part vibrates a lot, that could lead to fatigue at the transition point.
As a "rule of thumb", in the "custom" doublers I've made, I've made the doubler out of material the same thickness as the original material. But I know this doesn't help with specific documentation like AC43-13. I also would be interested if someone finds a proper engineering reference for it.
I installed a conduit in the VS as you described and it turned out to be invaluable - I have 3 devices up on the top of the VS that I had wiring runs to.
As charrois pointed out, in the vernacular "doubler" = doubling the the total thickness. Therefore the doubler is the same thickness and material as the part it is reinforcing. In a different example, if the reinforcement patch was double the thickness of the original part it would be a "tripler" since the end result would be a total stack up of 3 times the original thickness. And so forth. Again we are talking rules of thumb.
One of the reasons for sticking to the original thickness (doubling) is to provide adequate reinforcement without over-doing it. So a "tripler", "quadrupler" or other thicker reinforcement might be stronger in and of itself but this increase in thickness can cause a loading spike at the edge of the reinforcing patch resulting in localized stress concentrations and sometimes uneven fastener loading (like the proverbial highway construction crew, not every rivet pitches in to help). A generalization for sure as there are many more factors about the geometry and loading that can affect the design. Thankfully these aren't usually a problem with an aircraft the scale of an RV-10, especially at a tip rib which isn't as loaded as root rib structure. AC 43.13 helps with generalized accepted procedures for light aircraft.
The fact you are even asking about this bodes well for a good build. Good job.
Good discussion on this thanks. I've never thought about the problems that having a "doubler" that was too thick might cause.
Learning, learning, learning, always learning!
Welcome!
Congratulations on your decision to build an RV! Another Data Point. The 10's vertical stabilizer's ribs have lightening holes in them, all except for the top-most one. You can pass your conduit through them without having to drill any holes in the structure (this is best). You will have to drill a hole in the top rib (cap), so keep that hole and its conduit as small as possible (like 3/8" or 1/2"). If you do this and keep that hole well away from the edges of the cap, I would think you'd be okay without a doubler. You might need a doubler if you're going to mount an antenna or something up there. A lot of 10 builders have used this area to mount their "cat whiskers" NAV antenna up there. Personally, I did not change the vertical stabilizer structure at all from the plans (no conduit, no rudder trim servos, no nothing), but there are certainly a lot of people who have. One thought about cameras: One benefit to going with an exterior mount, like the ones sold by some 3rd party vendors, is that 1) they've likely done some engineering to design the mount, 2) they've got some history with people flying with the mount, and 3) you can change out the camera as technology improves and the cameras get inevitably smaller and lighter. If you hard mount something, you're stuck with the mount, the location, and often-times the camera model. MY $0.02. Happy building, and welcome to the madness. ;)
I too built my VS stock.
In thinking of where to put my NAV antenna, I do prefer it up on top of the VS.
It would be next to impossible to secure a conduit inside the lightning holes of the VS at this point.
Would it be reasonable to only have it secured at the the top and bottom holes to pass the coax up through? Or should I just forego that idea and either put it under the HS or go with an Archer in the wingtip?
Vs
I am working on this right now, after my vs was built. If you haven?t built your vs, plan on putting a doubler with nut plates on the top rib.
I intend on securing the rg400 where I can...
Thanks to everyone for the very helpful replies thus far to this thread. In the intervening weeks I have been happily building away on the spars of my VS while still thinking about and researching this proposed mod at the same time.
As I said in my original post, I'm sure that I'm still way over-thinking this, so much so that I have roughed out a preliminary set of plans for the proposed mod, a copy of which can be found here .
Notice however, that I haven't added the rivet layout to the doubler yet-- that's because I'm stuck on this one, probably because I don't understand what I'm reading in AC43.13-1B.
Mainly table 4-9 (page 4-37 in my copy). According to this, I am supposed to use 8.6 3/32 rivets per inch for my 0.025 sheets. According to note c) I believe that I can reduce this to 75% or 6.45 per inch (single lap sheet joint). (I don't think note b) applies to me, since I'm not making an "intermediate frame" splice as shown in figure 4-20?).
However, I guess the problem is I don't really understand the definition of a "lap joint" as it applies to a doubler plate such as this, or more specifically how to calculate the width or "W" for purposes of table 4-9.
For example, one way to look at this would be that I should place rivets around the entire perimeter of my doubler plate (properly spaced, etc.). My interpretation of table 4-9 in this case would seem to imply that I should use a total of ~74 rivets (11.44*6.45)! That can't be right?
I could also look at it like I should only consider the "longest" edge as one "lap joint", interpret the math that way and space the rivets out appropriately over the entire plate. But that still comes out to ~28 rivets! Still seems way too much for this small of a piece?
I chose 3/32 rivets as opposed to 1/8 rivets because of the guidance in figure 4-5 (3x thickness of the sheet). But even if I went up to 1/8 rivets my math still comes out to between 16-42 rivets depending on how I calculate "W".
Anybody have any idea what I'm missing here and can perhaps point me in the right direction? As I said, no doubt I'm over-thinking this, but just want to educate myself and understand the correct way to figure out these sorts of problems.
Thanks again,
-Mike
If you are thinking about the conduit for a VOR antenna, may I recommend installing an Archer antenna in the wing tip?
All the operational reports have been VERY positive and nothing is exposed to poke your eye out.
vs stabilizer wiring
I was reading everyone's opinion and what they did in their build. I totally forgot about a tail light and sealed my skins already. I guess the proper thing to do would be drill out rivets to gain access to center nose rib.
I am trying to figure a way out to run conduit through the VS without removing the skin. Any assistance will be great:-)
Only downside about the Archer antenna is it’s not designed to pick up the 300 mhz glideslope band. Apparently it works to varying degrees but, if your planning on true IFR capability it would be best to install a dual band antenna like the Rami AV-520 or similar. Cost and install being the biggest deterrent. I decided to install the cat whisker style towards the top of the VS.
I have an Archer and it’s never failed to pick up a GS (SL30). Truth is GS signals are always fairly close in, a coat hangar probably works.
The Archer antenna itself is 3/2 wave resonant at 330 MHz, but the gamma match coax matching network is tuned for 110 MHz, and is off at 330 MHz. If someone was genuinely concerned about GS sensitivity, it is much cheaper to just duplicate the Archer in the other wingtip, but borrow an antenna analyzer and re-do the matching network at 330 MHz.
