Finally started my build when I ran into my first problem I finished clecoing the Vertical Stabilizer and called it a night. The next morning I noticed a small dimple on both sides of the skin where a rib (VS1202) is clecoed. It seems the rib in that area is too tight. I radiused the front edge of the ribs as called out in the plans so as not to deform the leading edge of the skin. It was a tight fit putting them in and did not feel right. While installing the skin over the Vertical skeleton, I had to radiused the front of the ribs a good bit.
So, when installing the Vertical Stabilizer Skeleton (VSS) into the preformed Vertical Stabilizer Skin, does the VSS go in easy? It seems that I cannot get the leading edge of the ribs to fit into the round leading edge of the skin without a good bit of pressure. See attached pics.
-Tom
-Tom
