Looking for advice. Installing dual PMAGs on a Vertical Power VPX Pro system. There are two options:
1. Use the VPX Pro to power the PMAGs until their onboard generator takes over, this simplifies everything greatly. I like this.
2. Use a dedicated IBBS battery to power the PMAGs through physical circuit breakers with a pass-thru to the main battery (already installed, would remove if choice 1 is the way to go).
Separate PMAG run-up test switches in either case.
I can see benefits to both, leaning towards simplicity. Any advice is appreciated!
