Then let’s see the data.How about a simple thought experiment.
In flutter flight test, the test pilot establishes a specific speed/flight profile, then applies an exciting input (literally) by using a control input.
The lift distribution on each wing BEFORE the exciting input is in a low alpha condition, so pretty benign, and the structure is happy and in balance.
If the air was perfectly smooth, and there are absolutely no external forces changes.... we could probably be way past VNE at this point.
Lets say the input is from the ailerons for a left turn. So, the right aileron is going to increase the lift force and the left decreases.
The secondary effect of the increased lift from the aileron deflection will be to twist the wing.
So if there is increased weight ahead of the spar, it will tend to amplify the right aileron's twist input and dampen the left. Of course there is inertia of that extra mass as well, so lets just say the twisting response due to a different chordwise mass distribution is going to change the wings vibration twist response.
The wing has several natural vibration mode shapes in bending, and in torsion.
But, one of the natural frequencies of the wing structure has this shape... the right leading edge twisting down, and the left twisting up.
The flutter analyst tries to make sure that the external forces at a given flight condition don't get close to the natural frequency of these different mode shapes.
So if the structure was analyzed and tested with "as designed" mass and speed distribution, then it gets changed outside of the design parameters, stuff happens that may be more exciting than one would like.
Today's computer simulations of flutter models is quite good these days. And it's actually pretty easy to add mass to the finite element model at different locations to see the impact of different loading and flight conditions.
Start of totally unsupported speculation:
An engineer somewhere decided to do just that. Looked at the results and said 'Oh S%^t'
Ken provided data on his er tanks; there is currently nothing to refute except a vague, all encompassing Vne reduction.
It is also an ambiguous statement in that it referencing only total fuel and specifically states the location doesn’t matter.
Since only total extra fuel is referenced, it would be an unsubstantiated assumption to think that the reduction is for half the fuel as in most cases, only half the fuel is carried in each wing section. We really do not know but reading the statement would lead you to multiplying the extra fuel by 2.8 and subtracting it from Vne.
So here is another thought experiment. If the only thing that matters is the total extra fuel carried, and location doesn’t matter, what happens when we put all of the extra fuel in on wing? How does that change the flutter characteristics? Taking it a step further, again considering that location does not matter, let’s put the extra fuel in the back seat area. Could easily fit 20 gallons or more in those areas and still be well within the max gross weight. The way the statement is written, though, I would incur a 56 knots decrease in Vne. If, however, I put a person there instead, I have zero reduction in Vne. Again, location doesn’t matter.
Do you see the problem with the statement that was made?
