Actually the opposite applies. If you have the cylinders overhauled, the valve seats and/or the valves, may need to be reground. This causes the valve to sit lower, effectively making the valve clearance smaller. I personally had to replace the push rod to a shorter one in order to have the appropriate valve clearance according to Lycoming spec.
