JackinMichigan
I am wrapping up my build.
I used epoxy and micro balloons to fill the window cracks and on top of the cracks I used epoxy and fiberglass cloth. I used a lot of epoxy and fiberglass on the forward lower windshield.
After a lot of sanding, I am using a light coating of bondo to smooth out the edges and fill the little pin holes. I have already done it, so don't warn me not to do it..
Now my question: I want to fill the crack and pop rivet holes on the edge between the fiberglass canopy and the aluminum fuselage. It is pretty easy to do it in bondo, and it is not anything structural. Before I do this, I thought I would ask for your opinions. Note, if I fill it with epoxy and micro balloons, I will probably still finish coat it with bondo.
