greghughespdx
Van's has published a new revision of the RV-12iS Maintenance Manual. The list of updated items is below, and the PDF document may be downloaded from the Service Information section of the Vans web site.
https://www.vansaircraft.com/service-information-and-revisions/mm-maintenance-manual-2/
RV-12iS Maintenance Manual v3.1 ? Change List
- 1-21,22: INSTALLED EQUIPMENT LIST, updated the Skyview Weight and Arm values
- 3-8: FIREWALL FORWARD, removed cotter pins as inspection item
- 3-9: FWALL FWD, added ?Check exhaust sys. ball joints for proper anti-seize lube?
- 4-2: Moved ?Cherry Max CR series rivet ...? note to Page 17-3
- 14-2: ?EX-00030? in the Components table was ?Muffler Assembly?
- 16-3: Added QR code link to how to video to access ROTAX 912iS fault info in EFIS
- 17-3: Revised ?rivets? section
- 18-3: Added ELT Self-Test, Insp. bat. Life for RC Panel & Audio Alert Ind.
- 18-15: In the INSPECTION CHECKLIST add the ?Self-Test?
