O320-E2A installed in rv6. Wide open throttle 13-13.5 gallons per hours. Pretty even cht’s and egt’s. As soon as I come off WOT throttle cylinder 3 and 4’s egt’s rise substantially while cylinders 1 and 2 stay relatively cooler. I’ve checked and replaced intake boots and gaskets with no change. Borescoped intake tubes down to carb and found noting notable. Bypassed primer system with no change. Top plugs are on Bendix mag and bottom plugs are on electro air electronic ignition. Spark plugs are as shown in pics. Cylinder 1234 from left to right in pic. I’m not sure if this is a problem or the nature of the beast. Considering sending carb for bench test/rebuild. Thought?
