jull_under
Active Member
Hello All.
I've purchased the RV-4/8 servo mounting kit for Dynon.
Per instructions, this requires to drill out the old bracket & match drill the holes followed by installation in the same place.
As you can tell from the 2nd pic, installing the mount will be challenging in a hard to reach place.
What type and size of rivets did you use to do this...
Option 1 - Pop/Cherrymax. Can you get a rivet squeezer in there. Can a pneumatic squeezer work OR
Option 2 - Solid rivets. This may require removing the main elevator control rod since you won't be able to get the bucking bar in there
Any other ideas?
Thanks !
Any other ideas?
Thanks !
