Tunnel floor brackets on EFI aircraft
unitink72
For those of you that did EFI (I'm doing SDS if that matters), is there any use for the fuel filter and FloScan brackets which the stock plans have you put at the bottom of the tunnel?
Wondering if its handy to use these for anything or should I just dimple and fill with a rivet?
What Dr. Mark said!
You never know, you may be able to use those parts for other things too.
One thing that comes to mind is Ed Krantz used one of the fuel filter brackets to mount the Aerosport NACA vent controller to a j-channel stringer in the battery area.
