Hi All
I think I am finally (after years of looking, watching and probably not enough learning), ready to commit to an RV. It will probably be a 4 as I have been talking to some sellers (in Canada). But I have some questions that I hoped could get some brief answers. Don't worry about too much detail. Save the typing for when I really own one and then will need you to hold my hand.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
One, an older model (mid 80's) has no lights, electric trim or fuel primer.
Lights....I would really like to have lights on whatever one I get, not that I am going to venture off in the dark, but it does extend the flying day if necessary. I have looked at the FlyLED's stuff a bit. Looks good but are other options available? Will I need to change wing tips or are kits available for most tips. I am thinking there are only a few types of tips..?
Electric trim....one had a manual trim, which is fine for flying but if I wanted to add an autopilot ie Garmin GMC 507, is it hard to modify an older 4 in this way? I wonder what the weight differential would be. The control head would be light as the servo. Removing the trim linkage would remove weight so I would suspect a negligible weight change...? Or am I wrong in that reasoning?
Fuel Primer.....one had no fuel primer pump. O360 engine. Primer recommended? It has been flying for a long time without one but it seems from my limited research, a primer pump is common.
Props.....Most RV4's I have seen have wooden props. Is the reason for that cost or are there other reasons? I would feel better with aluminum but probably mostly cause all of my certified planes have had metal props.
Rear rudder pedals.....I few I have looked at over the years have no rear rudder pedals. But some do. Are they hard to add to a built aircraft? I will be a relatively low time tail wheel flyer and totally new to aerobatics so it would be nice to have the security of a back seat pilot with rudder control. Or are they just generally in the way due to the small area in which they would go?
I think that is enough questions for now. Answers will give me lots to think about and to do further research as I continue my search for an RV4 (or 8) I am looking forward to being part of the RV community, albeit I am not a builder.
Shawn
Shawn
