Finley Atherton
Trio Mandatory Field Change applies to all Gold servos.
Some time ago I had a Gold Standard Servo and the pressed pin was somewhat loose in the shaft/hub. The pin had not moved from it's correct position but a gentle push on the end of the pin could easily move it. I sent the servo back to Trio and they replaced it with a new one.
Fin
9A
Fin
9A
