Trim Wire - Length from End to Red Band? (WH-P30-1)
Antonitis
Member
Hi,
The red band of heat shrink tubing on my trim wire slid to the end while I was installing it. Can someone measure where the red band is placed in relation to the end of the trim wire?
Jason
Red Line Length
Hey Jason,
I believe you are working with the WH-P30-1 harness, correct?
We put this piece of heat shrink 4" from the end of the jacketing. This is 7" from the end of the wire / connector.
