A few months ago, I noticed that my oil temperature occasionally seemed high. Recently, during a flight, the temperature spiked to over 250°F. I decided to turn back to the airport, and during the steep turn, the temperature dropped to normal levels, only to spike back up once I leveled out.
After reading through some forums, I found that someone with the same avionics (AFS 3500) had experienced a similar issue. It was suggested they pull the alternator fuse to see if that was contributing to the problem. On my next flight, I tried this—pulled the fuse—and watched the oil temperature drop from 250°F to 170°F.
However, during that same flight, my CHT started reading high. Pulling the fuse caused the CHT to drop by a few hundred degrees, but it still showed elevated readings for the rest of the flight and taxi. When I toggled the master switch while shutting down, the CHT readings returned to normal.
I initially suspected a grounding issue but haven’t found any problems there. I’m wondering if anyone else has experienced this or has any insights into what might be causing it?
