Torque Values
RFSchaller
Patron
I noticed a small oil weep from the crankcase drain plug forward of the oil return line connection during my annual. The parts catalogue used to have all the torque values, but doesn?t seem to have them anymore. The Line and Heavy Maintenance manuals don?t have anything on the plug torque. I put reasonable force on the wrench and it didn?t budge. Any ideas on where to find a torque value?
Hey Rich - I sent you a link for a legacy rotax manual, which has a diagram of the fittings and if I?m correct in the fitting you mention it has a torque of 26 ft lbs and loctite 243.
Have you tried putting an impact wrench on it ? When overhauling car engines I always found that worked better on stuck bolts that straight wrenching
