I disagree. The most used non-jet fixed wing in the military, the C130 Hercules, has a front wheel. It was specifically designed for rough field use as well as smooth. Placing the c/g between the wheels is a more stable arrangement.
What? You're saying we're both wrong?
I'm snowbound here in E. Washington, unsuccessfully trying to get over the closed, avalanche-prone mountains passes to where I was supposed to be this weekend, so I've got time to kill...
I don't disagree with you. I'm sure that stability probably was a big part of it, but did they all of a sudden learn about physics, c.g. and stability in 1945? What was it about the end of WWII that changed things all of a sudden? Perhaps the answer to why military aircraft went to nosewheels could be all three: better visability, better for the jet age, and better for stability. I know it's not cool to have more than one correct answer
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
, but I'll put my historian's hat on:
What happens in history is almost always the result of multiple causation.
When things happen in history is a result of those multiple causal factors aligning at the same time. [Historian's hat off.] Time for the military aviation trivial pursuit players to weigh in!
But, to keep this relevant to the thread that was originally started, go for a -7!
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I wrestled with this issue long and hard and finally went with my gut. Once I did that (over 2 years ago, now) I've NEVER looked back. Good luck with your decision.
