Does anyone know if the crankcase breather tube of the Titan XIO 360 has a vent hole in it somewhere? If so, where? I didn't see one the last time I had the cowling off of my RV7A..
I'm using one of those desiccant systems which helps remove condensation from the crankcase (Black Max) and I want to be sure that I insert the plastic tube far enough to to be upstream of the "piccolo" vent (that's what it was called on the Continental IO 520) so that the Black Max unit will pump the dry air into the crankcase instead of out through any upstream vent.
