Kilo Charlie
Active Member
I have done lots of reading on here (THANK YOU) and spent some time in the hangar and I want to make sure I am getting this right before I go too far.
I am building the front of the tip up canopy frame and trying to mate it to the fuselage. I understand that F-702 skin lines up with F-771 (the forward most top skin) and also the side skins of the fuselage. I saw people using tape, straps and pixie dust to make this happen (by the way if you have any extra pixie dust please let me know because I am all out). Is it fine to crank down on straps to get it in position and then drill the C-614 splice plate and hope for the best?
I am using wooden blocks to put pressure on the high spots to bring them down.
I just wonder how much spring back is too much? Should it sit in place unaided or its fine to MAKE it fit.
Currently I have the 90-95% solution and I wonder if I can just bend the leading edge of the skin (F-702) down in the 2 places that it is sticking up. The worst is shown here:
it's about 1/16" too high but inline everywhere else.
Also I have debured the frame and skins but NOT dimpled/countersinked yet, should this be done now or after drilling the splice and ribs into place. The plans leave everything undersized so I am assuming things can/should still move a little?
I have also left the angled row of rivets undrilled on the sides of the frame. It sure looks like the skin would create a flat spot instead of the nice radius if I Cleo and install rivets there, I think I may make spacers once everything else is in place. Or is this under the canopy and doesn't matter?
Thanks for any pointers you have,
KC
![sddxg2.jpg](/proxy.php?image=http%3A%2F%2Fi62.tinypic.com%2Fsddxg2.jpg&hash=48b84a3a124fdb5b8bb9f4170a96d38a)
![70e6xl.jpg](/proxy.php?image=http%3A%2F%2Fi62.tinypic.com%2F70e6xl.jpg&hash=dd798e42a18e416585c6f7541647c6bc)
KC
