woodmanrog
I was having a problem with my Trio AH oscillating when it was initially depressed trying to find and hold altitiude. I plumbed it into the static line with a tee at the center and this helped but the problem didn't completely disappear. I was going to put in a new static port in the fuselage next to the existing one and it was suggested that I run a long static line to the tailcone and secure it with tie wraps and see how that works. This would eliminate punching another hole in the airplane. I followed this advice and have to report that it works perfectly. I did attach the static port hardware on the end of the line to decrease the 1/4" tube opening. I did try setting the null rates to various settings prior to this installation and it helped a bit but the plane still seemed to hunt for altitiude quite a bit before settling down. Problem solved.
