claycookiemonster
I'm measuring carefully to get the required length for the outer sleeve of these cables as well as the length needed for the actuator within. So far, so good.
The challenge is that the "throw" distance at the quadrant isn't the same as the "throw" possible at the actuator end on the engine.
The Throttle lever in the cockpit has a throw of 2.25" at the quadrant, however the actuator on the Servo has a throw of 1.8"
The Mixture lever in the cockpit has a throw of 2.2" at the quadrant, but the throw at the engine is 2.5"
The RPM (CS Prop) throw in the cockpit is 1.6" while the throw available at the engine is 2.1"
So, the Throttle lever has more movement than the engine allows, while both the Mixture and RPM levers do not move enough to actuate the engine controls to their full range.
Several questions arise:
1. Can I, should I assume that the controls in the cockpit will need to actuate the levers at the engine to their full range?
2. It seems obvious that altering the throws could be done by drilling new holes in the levers in the cockpit more easily than altering things at the engine end.
3. It also seems possible to add some sort of intervening bell crank between cockpit and engine, but that feels like going down a rabbit hole and hoping to find a way out later.
Thoughts?
Thoughts?
