BobCollins(AA)
I have a IO-360 cold air induction with horizontal fuel servo and I am looking for brackets to support the appropriate cables. Where can I get the brackets ?
It might look different in person, but from the pictures I would not do it this way. This is an area for perfection, since failure can be rather severe.Hey guys, I was admiring this problem for a while, and decided I really didn’t want to cut the vans bracket significantly to fit it on the bottom of the sump. I got a wild hair to put the bracket on top. It makes the arm geometry a bit funky, but I found a sweet spot that allows stop to stop with smooth action. It did require a hole closer to the pivot point for the cable side to give enough throw. Does anybody see an issue using this solution? Thanks!
Memphis
Exactly what Paul said - the angles are much larger than I believe these kinds of things are designed for. The ideal would be completely straight motion, and the rod end bearings are there just to deal with the small angle changes due to the lever length and throw of the cable.I appreciate the insight. Out of curiosity, what concerns you from the pictures? Just trying to learn!
Memphis
Or better yet did anyone take a different path and find a bracket made specifically for the Superior cold induction and Silverhawk EX setup?
+1 ! .Wendell,
I’d get rid of that spacer on the mixture bracket and use a shorter bolt. You can get the angle much straighter.
Wendell,
