Throttle & choke cables
08FATBOY
Member
Currently working on section 50-05 and 50-06. On 50-05 part CT-00101 and on page 50-06 part CT-00100, both parts have very small set screws, are they SAE or metric, anyone record the sizes? Also, should we use any Loctite on them? The set screw on the CT-00101 turned in by hand seems loose in the brass threads.
Thanks!
ROD
120162
If you are referring to the set screws on the throttle stop bugs they are SAE 0.05 Allen heads. At least that's what I'm using on them
