Messy area
If you are planning on a O-360 that area where the fuel pump doubler, throttle cable and carb heat cable all interfere with each other. Much easier to deal with off the airframe. The cable eyeball makes directing the throttle easier but takes more space.
The easiest method is to increase the size of the doubler. But I needed to order the eyeball and couldn’t remember the correct diameter.
