Throttle Bracket Drawing
Sully73
Active Member
Patron
I'm on the final stages of my RV-8 with I0-360-200 with horizontal induction. I saw a throttle bracket that I like and plan to fabricate one. See attached the photo. Does anyone have a drawing of this bracket they could share with me? Even a rough sketch showing hole locations would save me a few hours.
Let me know
thanks Jon
I should clarify, mine is a Superior IO-320 with a Superior cold air sump on an RV-9A with a Precision Airmotive horizontal injection. The pix above is actually the mixture control bracket which uses the Vans lever, rod ends, fasteners and bushings. I made a different mounting bracket than the Vans bracket due to the shape of the bosses on the cold air sump. The throttle bracket picks up existing holes on the cold air sump.
