Those with Control Approach Pedals.....
ethand
How did you route the aft heater hose? With the rudder pedal cable connections in the tunnel and in the path of where the plans have you route the heater hose how did you manage?
Squeeze the hose to an oval shape so it fits between the rudder pedal swing arm and the F-1048-R forward fuselage rib or some other idea?
E
Check out Mark Cooper's RV-10 wordpress blog here and here
If you search "Control Approach Rudder Pedal install" on google or bing you can find a few more.
If you swap the scat tubes so the rear seat one is on the right hole in the firewall you should be able to route the hose between the two pedal arms. The scat tube has enough rigidity it should stay between them ok then you can make the bend back to the scat tube bracket inside the tunnel once you are past the cable arms.
