NEVER FORGET
woxofswa
Van’s Aircraft
Manchu16
jeremyL
www.vansairforce.net
OFF TOPIC:
woxofswa
RV-10 door falls from sky (Texas).
vansairforce.net
Van’s Aircraft
Answers to questions about formed aluminum parts
Van’s Aircraft has recently received questions from several builders about variances in the depth of stiffening rings and beads in formed aluminum ribs. Variances in the depth of stiffening rings and beads for these parts have existed for years. We understand why people have questions about...
Manchu16
Grinding when turning prop
After a bit of troubleshooting, I figured it out, but I thought I should post it here in case others ever experienced this. Symptom: when rotating the prop by hand, I would feel a distinct grinding feeling. This would only happen immediately after shutdown when rotating the prop to put the...
jeremyL
Sika slider C-653
A question to those that have bonded their canopies with sika. Did you bond the C-653 cover strip with sika or some other way? Another option I was thinking is that since it’s bonded, there isn’t a need for the cover strip? I just bonded my canopy and it went super well and I’m pretty sure that...
OFF TOPIC:
vansairforce.net
