SuperCubDriver Trip Update
Perry flew me to Greenville Downtown this morning in his C-172 to pick up my RV-8 with the repaired canopy. It was sad to say good-bye and especially when it hurts a quick good-bye is what I like. I owe him many thanks and more and hope our paths will cross again.
RN8
Sportquattro
Foghorn Paint PIREP
Probably about halfway there now. I’m installing sky designs wheel pants. I’m on about day 5 of sand, prime, sand, prime, etc.
TASEsq
sellis
OFF TOPIC:
Another extended weekend trip
The school was on the way, not the slightest detour. A wildfire developed northwest of the school, large cloud, could smell it. The fog at LAX and Torrance disappeared so could fly as planned. Torrance temps at 23C, very nice after having 33C at Buchanan. Over LAX
vansairforce.net
RN8
Need a better understanding of nut plates/jigs
I bought a nut plate jog set from yard store, today was the first time I went to use them. I hope folks can see in the photo but the jig spacing is much narrower than the nut plate I was attaching (for counterweight in RV10 rudder if it matters). I made do by clamping the nut plate in place...
vansairforce.net
Sportquattro
G3x Touch and GTR225 communication issue
Evening all, I have a problem which has us baffled and are hoping you one of you knowledgeable folk can shed some light on the possible solution. In my aircraft I have a G3X Touch system comprising a 10” GDU, along with a Garmin GTR225 Comm Radio. We recently removed the previous Intercom...
vansairforce.net
Foghorn Paint PIREP
Oh so close
Just spent three consecutive 10 hour days sanding and priming fiberglass pieces… 22 of them… over and over Parts look super smooth… paint this weekend perhaps
vansairforce.net
TASEsq
Painting under nuts on engine case
I have watched *all* of the engine overhaul videos I can find, and it seems that most people use little masking dots to mask off the areas on the case, and accessory case, where the hardware goes. Here is an example of the accessory case from one video: I am about to paint my engine and the...
vansairforce.net
sellis
Canopy Frame
Hi all, I need some advice. I'm trying to fit the canopy frame to a QB fuselage. Vans says it just needs some slight tweaking. However, after a LOT of effort to make this fit, I finally realized that if the rear pin and slider block attach bracket were actually centered on the frame, the...
www.vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
