The VAF News - 8.12.2025. #6371. IFR Ticket in 9A, Fuel Valve Scare, and more.
DeltaRomeo
doug reeves: unfluencer
Staff member
Milestone: IFR Checkride in RV-9A
…Mr. Greg Saulsbury
Ironflight
dr
N804RV
gregsrv14
William Johnston
RE Pitch trim tab actuation. Thoughts?
…fixnflyguy
I have the "per plans" actuator in the elevator. I bought my tail kit unfinished and it had the manual trim cut-outs already done, but I simply modified the shape of the mounting plate. The servo is actually attached to a removable skin piece. I think its simple, and elegant, removes easy for maintenance. I made my own style control horn that's part of the close-out rib on the tab. I ran a bundle ( In the sheath I plan to send you) of the wires to the control stick and have my trim for elevator and ailerons on the stick. the servo is well forward and affects the balancing minimally. If I had an original manual trim that I converted to electric, I would probably have done the short teleflex and servo under the fairing.
OFF TOPIC:
