RV News That Caught My Eye Over The Last Day or So ….dr
__________________________
RV12 Rotax 912ULS Engine Vibration…cactus man reply
There is also 4 aluminum engine mount bushings that you probably already have....if you are gonna do the work i always say might as well order all the hardware nice and fresh...YMMV....there was a S/B for soft isolators a long time ago... but as others have mentioned - make sure your blades are properly angled...carb balance....dynamic prop balance...gear box - maybe gear box....you can rent a puller and send that off for rebuild....
vansairforce.net
![Screenshot 2024-07-31 at 5.17.40 PM.png Screenshot 2024-07-31 at 5.17.40 PM.png](https://vansairforce.net/data/attachments/46/46049-70dda526630c4051bc6ec531329da5fa.jpg)
Stein Air Shirts Lead the Way from Texas to Tennessee…Tanya
vansairforce.net
![Screenshot 2024-07-30 at 7.35.30 PM.png Screenshot 2024-07-30 at 7.35.30 PM.png](https://vansairforce.net/data/attachments/46/46050-0de8b703be9067e8b31e566f1f647eab.jpg)
Oil pressure question
vansairforce.net
Rebuilding a Cowl Edge …CTCole
Got to be frustrating, but the cowling edge can be rebuilt. When completed the repair is as strong & invisible as the original. I cut one of the upper sides too much, had to build back about 1/8". The trick was to include fiberglass cloth on the inside, and clamp a flat form (with wax paper) on the outer, finish side, then trim back to the desired dimension. Some photos attached.
https://vansairforce.net/threads/cowling.228669/post-1783194
![Screenshot 2024-07-30 at 7.51.55 PM.png Screenshot 2024-07-30 at 7.51.55 PM.png](https://vansairforce.net/data/attachments/46/46051-7407929bf6be6c5f4c01b4a0f73f4d23.jpg)
Rear handle on slider canopy …David Lewis setup
I made small left and right finger lifts out of 3/4" angle, as well as a small center lift out of 'H' shaped aluminum. Shaped how I like them. Works great for me.
vansairforce.net
![Screenshot 2024-07-31 at 5.19.08 PM.png Screenshot 2024-07-31 at 5.19.08 PM.png](https://vansairforce.net/data/attachments/46/46052-16410d1f2c70361ab6082f16c4d2ab29.jpg)
![Screenshot 2024-07-31 at 5.19.16 PM.png Screenshot 2024-07-31 at 5.19.16 PM.png](https://vansairforce.net/data/attachments/46/46053-aaf1616580c11ef63b9f666858b81f79.jpg)
OSH’24 Field Reports (PIREPs / News / Pics / Recipes)
vansairforce.net
WDYDWYRTW? (7/27-28/2024)
https://www.vansairforce.net/threads/wdydwyrtw-7-25-26-2024.228571/
OFF TOPIC:
![IMG_4864.JPG IMG_4864.JPG](https://vansairforce.net/data/attachments/46/46054-005d327ec181a16ef6fc99bf9d8c89d6.jpg)
PS: Older issues of the ‘VAF News’ can be found at:
I have a 2017 model Experimental Amateur Built RV12 with the Rotax 912ULS engine. It currently has about 370 hrs on it. It has the 2 blade composite Sensinich prop. I purchased this aircraft back in February 2024 and did a pre-buy and condition inspection. The logbook entry for the condition...
![vansairforce.net](https://vansairforce.net/data/assets/logo/vaf-icon-192x192.png)
A trip to Tennessee had been planned for last fall, but instead we executed a cat caper for a long time friend and flew two cats from New Mexico to a place more likely to find adopters. Limited vacation dictated the trip had to be rescheduled. Yes, the kitties did find new homes. Since...
Hi I’ve got a Lycoming io-540-d4a5 that Im having oil temperature issue, around 235f so I wanted to see if the oil cooler was clogged. I installed a mechanical gauge in line to the oil cooler and inline from the oil cooler. The reading was around 95psi at idle to the oil cooler and around...
I’m finishing my slider skirts and such and think I need an aft handhold to assist opening. I’ve seen rear handles on sliders mounted on the top bar to help lift the rear from the outside. I do not want to drill my canopy. What options have you all used to help lift the back of the slider? I’m...
OSH’24 Field Reports (PIREPs / News / Pics .... post your OSH reports here!)
Attn: VAF 'Reporters in the Field'! Well, it’s that time of year again! If you’re at the show, and you feel like posting a note on what you’re seeing, who you’re visiting with, what news you’re picking up, please consider sharing it with us in this thread. You can upload up to 10 pictures in...
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
![www.vansairforce.net](/proxy.php?image=https%3A%2F%2Fwww.vansairforce.net%2Fdata%2Fassets%2Flogo%2Fvaf-icon-192x192.png&hash=253ac26c64e15348dec9ea91bd1c9a3e&return_error=1)
