The VAF News - 7.31.2025. #6364.
DeltaRomeo
doug reeves: unfluencer
Staff member
More Pics of supik’s RV-10 Rudder Trim Prototype
...sure, here you go. It's a prototype, I'll have to see how it works..
Some OSH Winners
RE Sigtronics and ICOM A220 install question?
Update: Another extended weekend trip
inktomi
MT Hub for James Cowling / RV-8?
RE: SDSFI Fuel Return Pressure Regulator Firewall Mounting?
I noticed that the SDS automotive fuel pressure sensor has no way to secure the bolts. So I made a Z bracket to mount it and safety wired the drilled bolt heads. I also exchanged the screws that hold the cover on for ones with drilled heads and safety wired those as well. I know of one owner where that lid started coming off and leaked.
RE: Dimpling aft wing spar by flap brackets QB
Problem: I’m having a problem dimpling the aft spar where the flap bracket is on my QB wing. I was able to use a rivet puller on the ribs by the bracket but the holes on either side of the bracket on the spar are a double layer (rib and spar). Any suggestions?
Solution:
Mothership
OFF TOPIC:
