The VAF News - 6.17.2025. #6363. Matt’s oil blockage mystery solved!!!
DeltaRomeo
doug reeves: unfluencer
Staff member
mburch RV-7
rockitdoc First Engine Start
June 14, 2025. First engine start. Everything went very well. Only issue was that rpms seem high. At full idle and engine sounding like it was running at about 500 rpm the PFD reading was 1400. And, when readings were 2750 rpms on the PFD, the throttle was still an inch from the panel. So, something is amiss. But, oil pressure was in the green. Fuel pressure read in the yellow, though. CHT's were 245 to 260F after 5 mins. Forgot the look at EGTs.
dr
Painted! NX514WW
OFF TOPIC:
