The VAF News - 5.5.2025. #6333. WDYD, -14 fuse lift, On Being Grounded, Avionics Circuit Update, CO Detector, more…
DeltaRomeo
doug reeves: unfluencer
Staff member
dr
bertschb
IX: On Being Grounded …Scott Chasten
Update: Avionics Circuit …csmith3603
Howdy there tony. I think it was 3.30 but can,t remember. I did finally get the switch and vane to work again. It was the Stall
Warning. I replace the entire stall warning with one from another aircraft, plus I replaced the clips to the micro switch.
I believe this was the second time thru this problem! Zenith grin.. From the start I thought the vane was bent and some yahoo was checking my
plane out and hooked the vane and bent it... I put some red and white tape around the vane opening to warn yahoo's to walk around it.
RE: Carbon Monoxide in the cockpit
…Brian Decker
Seal the aft bulkhead/skins at the rudder cove.
RNB -10
Mark Dickens
Romeo-Victor
OFF TOPIC:
