Wishing you and yours a happy, safe and RV-filled weekend.
v/r,dr
I like this idea and had one of my own shortly before this thread popped up. My largest temp differential is between #2 and #4 (I think this is typical) on an angle valve engine. Angle valve engines sometimes have issues with coked oil in the exhaust valve guides. The exhaust and exhaust valves are on the rear of the cylinder (R side of the images). I wanted to make a baffle that spans from the boss on the case to the baffling on the outside, and directs air into the fins on the front (#2) cylinder, which would also decrease the airflow to the #4 cylinder. Maybe a slight bend on top to direct the air.
Of note, it's an angle valve engine, and my CHTs are basically always cool. On a hot day in a slow climb off a high elevation airport, I can make #2 just barely hit 380 sometimes, but 300-320 is more typical. My concern is more about delta between cylinders than absolute CHTs.
OFF TOPIC:
https://vansairforce.net/threads/the-vaf-list-a-list-of-rv-related-lists.223964/
Past ‘VAF News’ issues:
v/r,dr
30 Years!
First flight of my RV6 was on this day in 1996 after 4.5 years of building. I thought I would never finish it. 30 years goes by way too quick. Took her out for a ride around Sedona this morning. May 26, 1996, Danbury, CT: May 26, 2026, Sedona, AZ
vansairforce.net
First Flight: Peter Nunn’s RV-3 | New Plymouth, New Zealand RV-3 #11523
https://www.vansaircraft.com/first-flights/peter-nunns-rv-3/
vansairforce.net
RV-7A #73840
Well, I've officially started building an RV-7A I'm the third owner of this Kit and if you haven't read Vans warnings about buying older kits, particulary the bit about unboxed, original packaging you should. When I unboxed the kit for the first time in its 14 year life, this is the result of...
vansairforce.net
Painting with John….
While we had our first two RV’s that we built (in Texas) painted at GLO Custom, a great paint shop in Fort Worth “back in the day”, our subsequent builds (in Nevada) have gone a different route. The Tundra and eXenos have never seen paint, but the little jet and now the F1 Rocket have been...
vansairforce.net
Lycoming #4 CHT Too Cold
There's a title that might catch your attention. Over the past 20+ years, on two RV-7s equipped with an IO-360-A1B6 (200HP, Angle Valve, Roller Lifters, Piston Squirters, Dual EI, 20°BTDC base timing), one parts built (Aerosport Power - Bart Lalonde) and the lycoming factory, I've...
vansairforce.net
Metal printing might be a thing now......
I know that 3D printing metal has been around for a long time. I must admit the last time I looked into it, they were having a lot of technical issues with the laser sintering process. and to me it looked pretty bad so I did not look into it further. I was about to start TIG welding my oil...
vansairforce.net
Control System Q. Section 39, Page 3: F-1089 rod-end engagement
Hi, I am working on Section 39, Control Systems, and have accurately followed directions to create the forward elevator pushrod F-1089. I am concerned that the rod end bearing engagement on either end is only 5/16” not including the jam nut. I am trying to understand what the minimum safe...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
