Hello from the back side of the Flu-B recovery timeline. Feeling more human by the hour. Some nice folks texted and emailed notes that helped. ‘ppreciate ya…
Easing back into work. v/r,dr
VAF POSTS & RV NEWS THAT CAUGHT MY EYE.....dr:
What did you do with your RV this Weekend?
Swiss14A sets the bar…
‘Vlad’
His replies need nothing more than his name as a descriptor. You know It’ll be amazing….
https://vansairforce.net/threads/5x5-nose-tire-on-9a-new-wheel-required.225374/#post-1755972
-8 Rear Battery Access Door Pics
…a request.
-14 Status Pic …descry
https://vansairforce.net/threads/sh...our-14-14a-project.139727/page-5#post-1756152
-7 Status …SilverEagle2
Despite the vicious rumors to the contrary, yes I’m still building. This showed up today. ALL kits now in house!!!
Well I’m in Deep Now …Oroyo
Picked up this old girl. been around but low hrs. Needs a few things but it has potential. Now I need to learn a lot, a lot. It will be an adventure.
io360, GA carbon prop, steam gauges.
Canopy Warning Light ...another entry
https://vansairforce.net/threads/canopy-open-warning-light-but-how.225134/post-1756146
Toggle switches for mags …sf3543
I have used this set up on several planes and it works well for me.
standard toggle switches for mags and a off/on/(on) switch and LED for the starter.
the stater switch is obviously off in the off position. In the middle position the starter circuit is armed and the light comes on. In thIs position I can use a remote momentary switch on the infinity grip to start or use the momentary on function of the toggle. After start up I turn off the starter circuit. A relay is used as part of the circuit to make it work.
I like it but YMMV
i have a circuit drawing if you are interested.
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
What did you do with your RV this weekend (3/23 - 3/24’ish)
Yesterday I took my Baron to Pahrump, Nv and picked up a prop for my RV-4. This one is metal. I have a Catto currently installed. Not sure that I’ll ever install it, but…. Today I woke up and saw that the weather was better than the forecast called for — rain all day. So I drove out to the...
www.vansairforce.net
‘Vlad’
…a request.
RV-8 Rear Battery Access Door Pictures!
Twenty years ago when I built my -8, I sort of pioneered an access door for my rear mounted batter in the “hat shelf” of the baggage compartment. It’s too small becasue I built it with “scrap on hand”. I am now building a Rocket with essentially the same baggage configuration and rear mounted...
vansairforce.net
Show us the status of your 7/7A project!
vansairforce.net
Well I’m in deep now
Picked up this old girl. been around but low hrs. Needs a few things but it has potential. Now I need to learn a lot, a lot. It will be an adventure. io360, GA carbon prop, steam gauges.
vansairforce.net
I like it but YMMV
I plan to eliminate the ACI switch and install two toggle switches for the mag/Surefly. What switches do you use. I would prefer locking toggles but open to suggestions. Also what do you use for the start switch When replacing the ACI. Thanks….
vansairforce.net
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
