dr
RyanWhite
kentlik (7A Rebirthing) Build Update Photos
….starting at:
FlyAmerica
erich weaver
Feder
outnumbered
RE: Canopy side skirt clearance
…Rv-12David
I ended up getting my frame in the ball park then moved on. Eventually you’ll have the canopy on with Clecos and you can see where you’re at. I had thought that the fit was off but when all was cleco’d together it fit quite well.
Freemans
12vaitor’s 3D Printed Stall Warning Cover
…more info.
The tab projects from the wing and moves based on the airflow. It is connected to a switch that opens when the critical angle of attack is approached (it is adjustable). Making it flush to the wing would defeat the function. Photo shows what it looks like with the cover and flag attached. For polished wings it is really hard to see the stainless-steel tab sticking out.
OFF TOPIC:
First Flight: Robert Sharples’ RV-7 | Melbourne, Victoria, Australia RV-7 #74208
https://www.vansaircraft.com/first-flights/robert-sharples-rv-7/
www.vansairforce.net
RyanWhite
Lesson learned cutting wire jacket
This is the wire bundle for my two stick grips. After two years of flying I had a failure with down trim on my pilot stick. Zoom way in on pic and you will see where I nicked 2 wires when I built it. I cut the outer jacket with a razor blade and obviously pushed too hard. 2 years later the...
….starting at:
RV-7A rebirthing
...I have to find a suitable place for the B&C regulator. Any Ideas?... I was really running out of room so I ended up putting mine upside down on the fwd face of the sub panel on the r/h side. The reason it's upside down is so that the adjustment screw points down, allowing me to reach it by...
vansairforce.net
FlyAmerica
To Dimple or not to Dimple?
In 29IS/U-10 step 3, they have us dimple the holes in the aft edge of F-01240-1. Then in 29IS/U-11 step 7 they have us cleco, then rivet both F-1202D-L&R onto F-01240-1 but I do not see anywhere where it says to dimple the holes in the F-1202D-L&R... given the skin is dimpled it seems like the...
vansairforce.net
erich weaver
Oil return lines
Trying to get to the bottom of an annoying oil leak on my -7A and it looks like it may be one or more of the oil return lines. Got the short rubber hoses replaced and switched over to the constant tension clamps so hoping that takes care of it, but looking at the hardware on either side of the...
vansairforce.net
Feder
AP aileron Servo mount in fuselage
Has anyone tried this servomount as described in the RV-6 ? Old Garmin G3X with Garmin GX repackaged TruTrak that can no longer be repaired. Replacement will require new wiring not only in new shielded wire due To CANBUS but additional. 2 wires Fuselage mount looks attractive for maintenance...
vansairforce.net
outnumbered
Transponder antenna placement for Garmin GTX-45R
Trying to decide between these two options for transponder antenna placement. Any thoughts/feedback? In tunnel right behind firewall Pro's - Short coax length to GTX-45R (which is behind the panel) - center of fuselage Con's - Close to exhaust (not sure of this really would be...
vansairforce.net
…Rv-12David
I’m just finishing the installation of the canopy side skirts on my RV-12is in preparation for doing the canopy front fiberglass work. When closed, the tolerances of the side skirt gap seem within tolerances, but when closing the canopy it can shift enough that the forward bottom corner of the...
vansairforce.net
Freemans
Wire size for B&C regulator. Curious, not important.
Same current and probably not enough run length difference of the individual leads to matter, most installs. Any guesses why different gage for field current to/from the reg? Something I'm not seeing?
vansairforce.net
…more info.
3D File for Stall Vane Cover
In case anyone wants this, I corrected the dimensions for a popular online 3D print file for a stall vane cover. This fits perfectly. Just attach the usual "REMOVE BEFORE FLIGHT" tag to the end. I can send you the file - just shoot me a message.
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
