VAF POSTS & RV NEWS THAT CAUGHT MY EYE.....dr:
From this weekend’s thread …jclark
Still more tedious work for the behind the panel "infrastructure", but for this first time, the pieces are in the panel.
RV6A. Back at it after 20 years of "Life Happens" and two other RVs.
Fuselage clarification …bertschb 14
I got a super fast reply from my email to Vans support. He said to use wheel bearing grease rather than Boelube and this is where he said to skip the primer:
Light switches in the power module panel
I am planning on incorporating a VPX Pro into my -14A build, so will have some space on the central wiring channel since I won't be placing the power module there. However, it looks to be a great place to incorporate ancillary items like light switches, USB ports and heated seat switches. Has anyone done this? I"m thinking of using the angled sides from the power module kit along with a solid top and cutting it as needed for switches. Any potential issues in placing the switches here instead of on the panel?
Oil Temp probe wiring; Overthought amateur question of the day
Trying to maintain fidelity with the G3X manual.
Wiring for the oil temp probe. G3 manual calls for a shielded, twisted pair.
OK. The contradictions are:
- Other TCs (EGTs, CHTs) utilize relatively expensive, unshielded, non-twisted TC leads.
- Flying leads from the Oil Temp probe are simple 22gage wires (no shielding).
Follow-up question. Shield would obviously have to float on the device end. What size unshielded window would be acceptable?
Anybody here get me smarter on this? Thx.
JeremyL 7A Status
Just moved her into a long awaited hangar. Time to really get things done!
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
What did you do w/your RV this weekend? (March 9-10, 2024)
...getting this weekend's thread started. I'm down for annual - WX is beautiful. :( VAFDR
vansairforce.net
Really stupid question. Page 29-03 step one says "Mask off the forward and aft mating surfaces of the U-01402 Lower Gear Braces and prime" Do they want you to prime the mating surfaces or the the entire thing except the mating surfaces? Why do they not want you to prime the entire gear brace?
vansairforce.net
I am planning on incorporating a VPX Pro into my -14A build, so will have some space on the central wiring channel since I won't be placing the power module there. However, it looks to be a great place to incorporate ancillary items like light switches, USB ports and heated seat switches. Has...
vansairforce.net
Trying to maintain fidelity with the G3X manual. Wiring for the oil temp probe. G3 manual calls for a shielded, twisted pair. OK. The contradictions are: - Other TCs (EGTs, CHTs) utilize relatively expensive, unshielded, non-twisted TC leads. - Flying leads from the Oil Temp probe are simple...
vansairforce.net
JeremyL 7A Status
Show us the status of your 7/7A project!
Horton Aircraft Deconstruction Service..."State of the Art in Takin' Apart" .
vansairforce.net
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
www.vansairforce.net
