VAF POSTS & RV NEWS THAT CAUGHT MY EYE.....dr:
Daily RV Pic
RV-12 Status …arattinger
This is my RV12iS almost ready to start testing systems integration. Putting the plane together has been fun
Heat (or lack of) in the cockpit
A new link added in 'The VAF List'
Rudder trailing edge potential issue
I'm working on my RV-10 rudder and I made a mistake and slightly creased the trailing edge in the wrong direction for one of the two skins. I tried to go back and fix it with the edge forming tool to bend it the other way. Now it is a bit "wavy" and I have a photo of the worst section of that below.
Between the tank sealant and the rivets will this end up working out OK as is? Is there anything else that I can do to fix it? Or will I need a new skin?
Building virtual RV-3 …Jslow2
Since its to cold to work on the 9 in the garage, started building a 3 in CAD
Canopy Rail Mel Tip
I painted the top of my canopy in 1994. It still looks great today. I tried many primers to no avail. Finally found what works. Scuff the area to be painted with Scotch-Brite, and paint directly with polyurethane paint and no primer. I used JetGlo.
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
Daily RV Pic
Daily RV Pic
vansairforce.net
I'm working on my RV-10 rudder and I made a mistake and slightly creased the trailing edge in the wrong direction for one of the two skins. I tried to go back and fix it with the edge forming tool to bend it the other way. Now it is a bit "wavy" and I have a photo of the worst section of that...
vansairforce.net
Building virtual 3
www.vansairforce.net
Canopy Rail Mel Tip
Painting the canopy
A question came up the other day regarding painting a wide stripe on a canopy. So what is a proper primer, paint and prep for the job? Concern about all the products that damage the plexiglass leaves questions. We would appreciate any input from the experts. Thanks, Larry
vansairforce.net
OFF TOPIC:
Doug Reeves Vans Aircraft Kit Forum Official Build Experimental RV
