bbaggerman
dr
jlisler RE harness attach points RV-4
Things You Learn. Jay Pratt edition
jackking123
IO390
OFF TOPIC:
Failed generator fuse
Finishing up the annual condition inspection I went out for a test run-up. Everything ran fine but I wasn't getting charge. Stator coils ohm'ed out OK so I figured it must be the regulator. Then I remembered that generator output goes through a 30 amp fuse on the panel. When I pulled the fuse...
vansairforce.net
dr
WDYDWYRTW 2 / 15-16 / 2025
… getting this weekend’s thread off to a start. The weather here in Dallas, Texas isn’t looking like we’re gonna be flying RVs much today. 😔 Good morning to work on the lawnmower. 😜
vansairforce.net
Front Seat Shoulder Harness Attachment for Crow Harness
I have an older (1990) RV4 and am ordering new Crow Harness for the front seat. In all the pictures for Crow harnesses I see the shoulder harness has a metal attach point for a single bolt for the shoulder harnesses. Is this just likely a generic picture or is that how they will arrive? In my 4...
vansairforce.net
Things you do because you you've done it that way before.
I remember very early in my time here, as a very newbie builder, I was an absolute sponge for any hints from the experienced builders. There was a thread about the right color of sharpie for marking things, believe it or not! Anyway, the consensus was that Blue was the best marker color. I ran...
vansairforce.net
jackking123
RV-12 AOA Probe Leading Edge Kit Questions
I'm building an RV-7 and plan on putting in the RV-12 AOA probe... The leading edge rib last rivet on bottom side is at the right angle, so the hole is there. My questions can anyone tell me about this KIT and the instructions. Instructions/Dwg (can you send picture or instructions) or explain...
vansairforce.net
IO390
RV6 aileron woes
I'm building new ailerons for my (bought, not built), RV6. Just before the chapter 11 I bought parts to build two ailerons and finally started them this winter. Unfortunately I screwed up - it went well until the last part, when I drilled the bottom spar holes too far forward and therefore too...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
